EGR plate delete on a 1979 7.5l 460
[B[Hello all, the old holley 4 barrel 1850 carb needed a rebuild so while pulling it off I noticed that the EGR was a plate sandwiched between the carb base and the intake manifold base.
My question is can I remove the EGR and the plate put carb spacer in its place? Currently the EGR isnt hooked to anything.
What do you think or has anyone had had any experience doing this?
/B]
/B]
That’s an interesting concept. I have over the years used JB weld to patch up all kinds of things all the way from cracked blocks to cracked motorcycle cases. I have even raced motorcycles across the desert that was patched back together with JB Weld. But you still have one problem; a square bore carburetors secondaries will not open on that manifold unless you do some grinding on those secondary holes. I am not sure how the JB Weld will hold up with all that expanding and contracting that the hot exhaust gases is going to make the manifold go through. That exhaust really heats up that EGR hole. Another advantage of the adaptor plate is keeping the carburetor cooler. I added the Edelbrock wood fiber spacer on top of the adaptor plate and it completely stopped the carburetor percolating the gas when the engine is run under hot conditions.
Hi Gary, Thanks for your input. I tried looking for the adapter looks like a carb spacer but has a ear on the side between the primaries and secondary at the mating surface.
Could never find one that completely covered that ear area.
I think after the points that you have made i will go ahead with the pre72 gasket and froget the JBWELD.
Thanks again for your input, Jon
That’s interesting. I never thought about a freeze plug. Would have saved me money on an adaptor plate. Ideally would be an aluminum performer manifold. That way you wouldn’t have the intake manifold getting so hot and you would lighten the vehicle by about 50 pounds. Can’t do that in California because of the smog checks. You can’t modify anything or its an automatic fail. I took mine in one time for grins and ran it through the smog check with the Edelbrock on it and the EGR removed and it actually ran cleaner than with the Factory equipment on it. I mean considerably cleaner. The Nox was 999ppm with the factory equipment and 110ppm with the Edelbrock and all the other numbers were lower as well. It passed with the factory equipment but of course failed with the Edelbrock. We need CARB ran by automotive experts instead of politicians that don’t know a differential from a distributor.
