What would cause this to happen?
Old 06-01-2014, 10:00 PM
rusbukt's Avatar
rusbukt
rusbukt is offline
Its a short video clip. Hope it works. Truck is not running. Watch ALT gauge. Click on image to view.
Old 06-01-2014, 11:17 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
It looks to me like you have a dead short - when the alt gauge goes to discharge - followed by the circuit breaker for that system popping - when the alt needle centers - then the breaker resets itself and encounters the dead short again so the needle goes back to discharge , etc. etc. There is a circuit breaker built into your light switch for the headlight circuit. I thought I heard your breaker popping in your video. I'd be looking in that direction. Of course, as usual, I could be wrong . . . Good luck.
Old 06-01-2014, 11:24 PM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
Mine would do that, and flutter and all kinds of crazy, stopped at NAPA, new Voltage Regulator, only moves when it needs to now.
Old 06-02-2014, 02:09 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
The alternator regulator used thru 1981 has points, which are notorious for getting stuck.
Look at the cover, if it has dents, people rapped on it with their knuckles or screw driver handles to unstick the points.
1982: Ford replaced the points type regulator with an electronic regulator. It has a nearly flat aluminum cover with MOTORCRAFT embossed on the diagonal.
Get one a these, eliminate the points. Nothing needs to be changed, just bolt it on, plug in the wiring harness...and that's it.
Old 06-02-2014, 08:18 AM
rusbukt's Avatar
rusbukt
rusbukt is offline
Thanks men! I'll pick a regulator up today.
Old 06-02-2014, 06:35 PM
rusbukt's Avatar
rusbukt
rusbukt is offline
You nailed it SuperSabre. After replacing voltage regulator and HAVING NO LUCK. (always good to have a spare)
Wiper motor was burnt. It was still nice and toasty warm after having the key on for 15 min.
Thanks for the help. Owe you a cold one.
Old 06-02-2014, 09:30 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Then you remove the top from your Autolite correct regulator and place it on your electronic Motorcraft regulator. No one knows but you as my four Fords all have that. Got lucky as someone had a screaming deal on Motorcraft regulators several years ago on eBay.
Old 06-02-2014, 10:46 PM
rusbukt's Avatar
rusbukt
rusbukt is offline
Looked at a NOS Autolite on eBay this morning. 495.00 or some crazy number like that.
AutoZone 22.00.
Thanks for the camouflage tip.
Old 06-03-2014, 01:19 AM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Yeah, forget NOS Autolite points regulators. I got the 5 US made Motorcraft regulators for $19 each. Then one can get correct covers from many vendors like NPD or AMK.
Old 06-03-2014, 08:09 AM
NumberDummy
When the electronic regulators replaced the old point type, some people that owned old Ford's with the Auto-Lite regulator complained about the electronic cover.
I told 'em, remove your original cover, install on new electronic regulator, NO ONE will know the difference.
The alternator point type regulator covers are the same: 1963/64 Thunderbird/Lincoln - 1965/81 everything else. The original Auto-Lite regulator cover was painted black.
1972/81 Motorcraft regulator cover was painted blue. Motorcraft replaced Auto-Lite in 1972 after Ford was forced by the US Gov't to sell Auto-Lite in 1971.
nonoodlez
02-28-2015 11:07 AM
jasindude1
09-18-2014 02:33 PM
sgt.bigjim
22
10-10-2013 09:49 PM
KM04Excursion
10-28-2011 07:49 AM
the lost boy
11-10-2003 10:25 AM
Quick Reply: What would cause this to happen?
