Fuel tank Delete on 96 F150
#32
Near as I can tell that is normal.
#33
#34
#36
Very true, it is always up to the owner to do what they like on the repairs of their vehicle.
I prefer both tanks, and I use the bronco tank whenever I replace the rear tank. I'm going to try the f26 tank soon for the little extra over the bronco tank. My 460s are thirsty buggers, and my 351s love to drink.
The only way I'd get rid of the front tank, is if I had a 2wd toy, a 460 hotrod. That way I could dump the exhaust in front of the wheels without fender well headers.
That's just me.
That's just me.
#37
I couldn't bring myself to buy the less expensive replacement pump and hanger, so I went with Motocraft. But that did seal my decision to remove the rear tank. Now, to plugging the fuel lines, I like Conanski's solution, but that looks like it would plug at the end of the supply/return fuel lines, and I don't want to leave that much fuel line.
This means I'll be cutting the braided fuel lines and plugging with a bolt or rod to fit the inner diameter and clamping with hose clamps. I found this OTC Tools plug but I don't see a good description of its use. Does this look like it would lock into the connector like Conanski's fab'd bolt?
But eventually it seems like the best solution is to replace the double function reservoir with a single function reservoir and be done with the patch work.
I've not had a lot of luck finding this work around, but I may be using the wrong phrases. I don't want to hijack this thread so let me know if I'm getting off topic.
#38
All the fuel lines from the tanks on your truck just go to a "T" fitting at the frame and then the pressure line goes to the filter and the return line goes to the fuel pressure regulator.
#39
Your 1996 truck does not use a double function reservoir or a single function reservoir.
After reading about this issue of leaving or removing the second tank, I feel a lot more comfortable leaving the defective pump in the second tank and disconnecting the power. It's still not clear to me what keeps fuel from entering the rear tank if there's no power to the fuel delivery module or check valve though. Is it the check valve on the working tank that prevents fuel from flowing to the rear? Or is it the design of the pump to not allow fuel to flow in from the high pressure side whether there is power or not?
I can't find the thread now where I read the suggestion to do this, but this solution gives me the option of at least adding a cheaper pump later to get both tanks back online again.
#40
...After reading about this issue of leaving or removing the second tank, I feel a lot more comfortable leaving the defective pump in the second tank and disconnecting the power. It's still not clear to me what keeps fuel from entering the rear tank if there's no power to the fuel delivery module or check valve though. Is it the check valve on the working tank that prevents fuel from flowing to the rear? Or is it the design of the pump to not allow fuel to flow in from the high pressure side whether there is power or not?...
#41
Even then there's the shuttle valve that could let fuel flow in, so all this puts me back to needing to plug the rear fuel lines by fabbing a plug like subford showed, or plug the fuel lines inside the hanger assembly. Plugging the hanger fuel lines seems best since that keeps everything in place if I ever decide to spend money on another Motorcraft pump, or buy a cheaper pump and call it a backup.
This thread has helped me understand the dual tank system on my truck so much better than the Haynes or online searches.
#42
#43
#44
#45
I'm planning on deleting my front tank in my "hot rod" f150, due to the fact that the tank is leaking, the pump is growing weary, and because it no longer serves as a daily driver, i see no point in having the dual tanks. when the big block comes, then i will run symmetrical duals, but one of the things i like best is the wight balance. i occasionally run autocross, so having the weights similar side to side actually does make a difference.
My plans to block the lines were that i took a dead fuel pump assembly fr4om a truck in this series, i cut the two fuel lines off the top plate ofthe pump, and then i soldered them shut/crimped the ends. does anyone else see a problem in that method?
