New guy with E4od issue
Love the website folks. Solved a lot of problems by he knowledge here so hopefully I can get some help. I have a 96 f350 with a 460 and E4OD. It is obd2 and I ran it on a computer test at my buddies shop and the TCC solenoid failed. I had a few issues I already fixed like the 3rd brake light and a couple fuses etc but my torque converter still shudders and if im pulling a hill and it downshift it takes a few seconds to lock up. The truck has plenty of power but it feels like its just not putting it to the ground. If I turn the OD off before I get to a hill it will usually lock right up but if its already up and then downshifts it feels like its slipping before it locks. Any ideas? Would a Banks trans-command bypass that solenoid? Thank you folks.
If the TCC solenoid is failing, you must replace the solenoid pack. The TCC solenoid controls the locking action of the torque converter directly through directed hydraulic pressure.
Honestly, it sounds like your converter's clutch is worn out, or your torque converter has a crack in the clutch apply piston. Either way, this warrants a converter replacement.
A banks transcommand does not bypass anything but the PCM (engine computer).
If your solenoid is actually bad, you may not need a converter. Best thing to do would to be to remove the solenoid pack and test the TCC solenoid with 12 VDC.
If it is actually bad, you should replace the pack. If not, you have either a blockage in the TCC hydraulic system, or a cracked converter clutch apply piston.
I don't know much about the banks unit.
OK. Unfortunately you'll have to replace the solenoid pack in the transmission. It's easy to replace but it can be expensive depending on where you get one.
First off there may be nothing wrong with the TC or the solenoid pack.
The PCM is electrically connected to the solenoid pack by way of a cable and plugs. The plug at the passenger side of the transmission may have bad wires going into the plug, very common. You need to test the wiring with an ohm meter going to the TCC solenoid while shaking the wiring on the passenger side of the transmission.
The plug to test with would be C103 pin #9 and any #361 red wire. The 361 wire goes to all fuel injectors and other points originating at the PCM power relay.
C103 is located at the LH side (drivers side) of engine compartment, top of wheel well.
E4OD wiring:
C103:
