Brake arm problem-pic
Old 05-25-2014, 12:19 PM
jrockdiddy's Avatar
jrockdiddy
jrockdiddy is offline
Trying to get ideas how to fix this problem. I have the cpp bracket with tuff stuff booster and wilwood MC. The brake arm is 1.5" away from the hole. The floor mount plate is from midfifty. I called and they checked the warehouse and said my brake arm was off of normal location. One idea was to heat and bend it. I was thinking about cutting it and putting a 1.5" spacer to relocate the pedal, but leave the mounting position the same on the cpp bracket.
Old 05-25-2014, 02:37 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
It seems like the pedal will be too close to the column, do you have a picture of the pedal/brake booster set-up on the truck.
Old 05-25-2014, 03:04 PM
jrockdiddy's Avatar
jrockdiddy
Old 05-25-2014, 09:18 PM
drptop70ss's Avatar
drptop70ss
drptop70ss is offline
If the booster lines up with the pedal ok I would heat and bend a "Z" into the pedal a couple inches higher than the pedal mounting point to move it over to the right. Torch and a vice will fix it right up.
Old 05-25-2014, 09:24 PM
jrockdiddy's Avatar
jrockdiddy
I'm gonna do some further inspecting tonight after work and see whats going on. I'm thinking the torch will be the quick fix, but wanna get a better view first. I'll post what I find...
Old 05-25-2014, 09:32 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,132 Likes on 2,656 Posts
I think there is a block that is bolted to the inside of the frame if I'm not mistaken that makes the mounting point inward by the thickness of the frame. I have a bare frame and can check tomorrow.
Old 05-25-2014, 09:36 PM
jrockdiddy's Avatar
jrockdiddy
Do you have a pic of this block?
Old 05-25-2014, 09:40 PM
56panelford
I'll take a pic tomorrow for you. I think it is like a section of frame that is reversed inside the frame. It's been awhile since I've looked so hope I'm not steering you wrong, it's dark here now otherwise I'd go and check and take that pic.
Old 05-25-2014, 09:45 PM
jrockdiddy's Avatar
jrockdiddy
You talkin' about this?
Old 05-25-2014, 09:48 PM
56panelford
Yes, that's the piece I was refering to, if you mounted what you have to it wouldn't that put your brake pedal arm i the correct position? You would likely have to remove the bushing.
Old 05-25-2014, 09:51 PM
jrockdiddy's Avatar
jrockdiddy
Not sure, I don't have that piece. My bracket is the entire pedal and bracket. Newer pedal. Looks like this piece...
http://www.ebay.com/itm/1953-1954-1955-56-Ford-Truck-Power-Brake-Booster-Master-Cylinder-Pedal-Assembly-/320760127635?pt=Motors_Car_Truck_Parts_Accessories&hash=item4aaecb2093&vxp=mtr
Old 05-25-2014, 10:03 PM
56panelford
There has to be someone on here that has installed one to tell you for sure. I think if you couldn't find one you would be able to make something that resembles it.
Old 05-25-2014, 10:09 PM
56panelford
1953-56 Ford F-100 Power Brake Booster Kit, Pre-valv, Disc-drum
Looking at the instructions from the Midfifty site it looks like you need that part
Old 05-25-2014, 10:40 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
It looks like the location is right, but the factory pedal had a bend in it. Not a Z bend, just a single angle near the pivot point. Yours looks straight in the pictures.
Old 05-25-2014, 11:31 PM
jrockdiddy's Avatar
jrockdiddy
That midfifty kit isn't the one I have. Effie, I agree with the factory pedal having a bend in it. Mine is straight as a whistle
Quick Reply: Brake arm problem-pic
