DJM beam kit camber seems out
Old 05-25-2014, 01:31 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
You don't happen to have lift springs do ya?
Josh
Old 05-25-2014, 01:51 PM
CDN Sharky's Avatar
CDN Sharky
CDN Sharky is offline
Ok here is a pic of me and the boy on it id say easy 380/400 lb. what do you guys think. Leave it be until she is all together?
Old 05-25-2014, 02:00 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Rogue_Wulff is offline
Looks to me like you have big block springs, and a small block engine........
Seriously though, the springs may just be too long/stiff for the application. If they are new, they may need a bit of time to "settle", but that looks like a lot more than can be attributed to "settling" of the springs.
Old 05-25-2014, 02:08 PM
redroad's Avatar
redroad
redroad is offline
I would agree .. Are the springs original to the truck ? and what does the Vin say was the original motor for the truck?
Old 05-25-2014, 02:28 PM
Bullitt390's Avatar
Bullitt390
Big block and small block springs do not make that much of a difference. Even moreso once the guys put their weight on it as in the demonstration.
Josh
Old 05-25-2014, 02:29 PM
CDN Sharky's Avatar
CDN Sharky
The vin says 302 I installed a 347 stroker with aluminum heads. The springs are the springs came with the truck.
Old 05-25-2014, 02:34 PM
redroad's Avatar
redroad
redroad is offline
Josh
On my F350 dually it was 1" in height
Old 05-25-2014, 02:38 PM
redroad's Avatar
redroad
redroad is offline
So the springs are what they are .. You might go with some variable rate springs, if those springs are original .. It will ride a lot better .. and then cut to fit when your all done putting it together
Old 05-25-2014, 02:40 PM
CDN Sharky's Avatar
CDN Sharky
I have another 1978 f100 I don't want to but maybe ill pull the springs of it and compare them. You guys think it makes a difference that the one im building is a 1978 1/2. is it possible the springs in there now are for a f150 that's heavier suspension right?
Bullitt390's Avatar
Bullitt390
Comparing an F350 dually to an F100?
Josh
Old 05-25-2014, 02:46 PM
CDN Sharky's Avatar
CDN Sharky
Ok there is 1 inch difference just measuring my parts truck is shorter it has in inline 6 in it. that could be it may have to switch them into it.
Old 05-25-2014, 02:53 PM
redroad's Avatar
redroad
redroad is offline
Josh
I'm comparing the difference in stock spring height in 2 motors only
  #28
Old 05-25-2014, 02:55 PM
Rogue_Wulff
That 1" difference will make a huge difference in camber. I bet it will sit much better on the shorter springs.
  #29
Old 05-25-2014, 02:59 PM
Rogue_Wulff
Yes, there is a difference. I put big block springs under a small block powered truck once. The result looked much like the pics posted by the OP.
Small block, around 450-500 lbs. Big block, 600+
  #30
Old 05-25-2014, 03:14 PM
CDN Sharky's Avatar
CDN Sharky
So before doing all that work I loosend every bolt underneath drove the crap out of it on my gravel driveway and now it looks like the pic I have not tightend anything but I may be good now. Seems like it was stress on it after all.
Quick Reply: DJM beam kit camber seems out
