Low boost, no power
Low boost, no power
I have 8 stage-1 injectors from Rosewood installed that are about a month old. There is no sign of oil in the coolant or oil in the fuel bowl. I just changed the oil and filter. The air filter is not dirty. The fuel filter is spotless.
It passed a coolant system pressure test.
I was unable to complete a compression test because my adapter is too fat to install. What I do know is that the 3 cylinders I checked have "at least" 320psi at idle. I couldn't get the compression tester threaded in far enough for the o-ring to seal.
Symptoms: No power, rough running under WOT, doesn't like revving past 2k, blows white smoke if you try to make it.
Monitored on my last drive (torque pro and gauges for HPOP and boost)
Boost: 0-4 psi. 4 psi is at WOT and only when it feels like it. It was pretty normal to get less than 2 psi. These readings were confirmed by both my MAP sensor and my mechanical boost gauge.
HPOP: 600psi at idle to around 2400-2500 WOT. Confirmed by both the ICP output and my mechanical gauge.
IPR duty cycle idled around 12-14 and never went over 40% for WOT.
Engine oil temp 60-80 degrees C. Seemed normal to me.
Injector pulse width: about 1600 micro seconds at WOT.
EBP: usually just a few psi higher than the intake. Never exceeded 22psi.
I have only found one bad exhaust or intake seal:
