Slave cylinder bleeding...???
Hi guys, tried using the search thing but can't find anything. Replaced the slave on my 95 F350, and now need to bleed it. When I crack the screw on it, oil comes out. But iam assuming there is still air in it somewhere because my pedal does nothing yet. I yes, I made the mistake of not buying the whole thing. Thanks for any help!
If you have the slave cylinder with the bleeder screw,wich it sounds like you do, Have somewne depress and hold the clutch peddle while the bleeder screw is open. Close the screw and let the peddle return to the "up" position, then repeat the procedure. If you dont have the bleeder, good luck.
deere55
01-27-2011 11:53 AM
srumble
11-17-2007 06:36 PM
1179
08-31-2006 07:03 PM
james91375
04-20-2005 08:00 AM
