Modular V10 (6.8l)
code P0171
Old 07-05-2014, 11:41 AM
wendal's Avatar
wendal
wendal is offline
code P0171
I just bought this 99 f250 super duty with 197k.
I changed all fluids and installed new spark plugs. I then changed the exhaust. I deleted the cat and replaced my muffler with a glass pack. Right after that I got a P0171. The pickup runs rough and jerks when driving it.
I cleaned the MAF sensor. I did replace the fuel filter. I check the pvc hose under the throttle body. It looks good.
What other hoses do I need to look at for vacuum leaks? I have read that it may be my O2 sensor.
It ran pretty good until I changed the exhaust. I did add some marvel mystery oil at the same time.
I did clear the code but still runs rough.
Another problem
My 4x4 light, service engine light does not come on when I turn the key on. All my other light come on then go off. My check engine light never comes on either.
My ABS light is on but I know what the problem is their. The left front wire going to the sensor is broke.
thanks for any help
Old 07-06-2014, 10:24 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Something's making it run lean.
Start by checking the fuel pressure, and make sure it's 28-30 at idle, and 38-40 with the vacuum disconnected from the fuel pressure regulator.
Any chance you have an exhaust leak ahead of the O2 sensors?
Old 07-06-2014, 01:35 PM
wendal's Avatar
wendal
wendal is offline
I will look into the fuel pressure.
I will look at the exhaust but I did not here anything.
thanks again for the help
Old 07-07-2014, 05:53 AM
CPaulsen's Avatar
CPaulsen
CPaulsen is offline
Check the vacuum hoses on both valve covers.
Old 07-07-2014, 06:40 AM
wendal's Avatar
wendal
wendal is offline
OK will do.
On the passenger side does the hose crack under the insulation? Can I cut it off and then zippy tie it back on?
Old 07-09-2014, 03:37 PM
wendal's Avatar
wendal
wendal is offline
OK I am sorry for the stupid question but where is the fuel pressure regulator?
thanks
Benjamin Silva
04-30-2016 09:00 AM
teamlx88
1997-2006 Expedition & Navigator
09-21-2010 09:29 AM
billkean
17
10-15-2009 11:32 AM
00GT
Escape & Escape Hybrid
09-14-2007 06:36 AM
cutez
12-19-2000 05:44 PM
Quick Reply: code P0171
