My first Ford pickup....
Hello all,
I picked up a 1983 Ford F350 Crew Cab dually for $700 recently. The truck's butt ugly but it ran and drove. It did have a few electrical issues so I bought it and thought, "How bad could it be?". Famous last words. Here are a few pics from when I brought it home:
Literally every body panel on the left is toast. I barely coaxed it home due to a dying fuel pump (or so I thought). My wife and I pulled the entire interior out and found all kinds of cut and spliced wiring (badly) along with a bad heater core and bad turn signal switch. And I discovered the cab's bent right below the driver side A-pillar. Lovely. But the truck was cheap and I'm good with the tools so I figure if I can fix everything for a grand or less I'll have me a great truck. More pics of the horror to follow.
Did I mention the cooling system looks like it sat next to the Titanic for a few years?
More pics of the carnage. Wrong air cleaner (from a Chevy!) was on the truck with the wrong filter in it. Rusty cooling system.
If you look closely you'll see a pile of rust by the hoses. That's what came out of the hoses when I flexed them. And they sounded crunchy inside...
Looks like the heater core was leaking for a while from all the gunk under it.
Bent cab.
Bent cab.
Literally every body panel on the left is toast. I barely coaxed it home due to a dying fuel pump. My wife and I pulled the entire interior out and found all kinds of cut and spliced wiring (badly) along with a bad heater core and bad turn signal switch. And I discovered the cab's bent right below the driver side A-pillar. Lovely.
IMO, by the time you have a great truck, the money you've poured into it (5-7 grand EZ) plus the labor spent, could have bought a great truck to begin with that needed little or nothing in the way of money spent on it.
The one mistake people make when they buy a beat up old rolling pile of misery like this is...they grossly underestimate what it will cost to fix 'em.
I've already set a limit for myself of $2k total on this heap. If I can't get it reliable by then I can part it out and get some of my money back. The 460/C6 combo and rear end are the best parts so far.
I just want a truck for hauling stuff in, doesn't have to be pretty, just reliable.
The shop manual for your truck is always pretty much a necessity. Reprints aren't usually too expensive? Or if you have a printer you can zap off .pdf from the web sites for specific areas that are being worked on. Hard copy is important/handy too.
Agree, if you want reliable transportation this is one way to do it, disregarding cosmetics. Don't see how to limit to a dollar figure on repairs though, wish you better luck than I've had.
