Man vs. Ball Joint
Man vs. Ball Joint
Among other things, I am trying to change out the ball joints on my 2002 Ford Explorer XLT 2WD 4.0L. I've been puttin' it off for as long as I can, but it's time to get it done! I've got everything taken apart on the first side, EXCEPT the lower ball joint. I can't get that sucker out! I've beat that pickle fork into that thing about ten times with no progress. I've looked at a few videos on YouTube, and I've read several threads on here, but I haven't even seen one that looks like the one I have. Most of the videos I watched showed vehicles with the smaller top control arm with the built-in upper ball joint. Mine looks like this:
The hub is off. The top ball joint is loose, but the bottom one isn't. The bottom ball joint shaft moves in and out. Am I doing something wrong? I saw one video that showed 2 pickle forks. Am I gonna have to have another one to wedge that thing out of there?
Any and all help and direction is greatly appreciated!!
You could also try jacking up the control arm and wedging something solid (ratchet handle, pickle fork, etc.) between the knuckle and the control arm. Then, lower the control arm. This only works if the clearance between the knuckle and control arm gets bigger when you jack up the control arm. I've used it on my Honda. On my Explorer, the pickle fork worked well.
If that doesn't do it, smack the knuckle near the ball joint stud to shock it while it's loaded. Of course, be very careful not to have any digits or appendages located such that they could get damaged when things break loose. I use one regular-sized hammer to smack it and a 3 or 4 lb hammer on the back side of what I'm smacking.
Is that steering knuckle aluminum? If so, be careful with the hammer. Don't want to cause too much damage.
Yeah, the knuckle is aluminum. I keep having these visions of that thing breaking, which definitely would NOT be good.
I've got both sides torn down to the same point now. I borrowed a few more pickle forks of different sizes. We've driven those things in as far as they will go, from the front, and from the back, and the lower joint will just not come free. One fork is about 3/4" thick! We even drove two forks at once in there a time or two. I soaked both joints with WD-40 before the last round of frailing. Maybe after it has time to penetrate more, something good will happen. Not sure, but maybe the steel joint inside the aluminum knuckle has something to do with it. Just hope I can get it soon. Need to have that thing rollin' by Thursday!
THANKS for the help, senix and Mikeman!!
Took a LOT of heating, but we were finally able to get those suckers to pop out of there!! I would've never thought it would take as much as it did. A smaller, hand-held torch would never get it hot enough. Thank God for oxy acetylene, and for neighbors who are willing to help! And that includes everyone on here!! Now we can start putting everything back together....
Well, I installed the lower first, then I used a jack to raise the knuckle/lower CA up to the upper CA. I can see where doing it the other way around might've been easier. THANKS!
When I tighten the ball joint nuts, how tight should they be? I've seen a couple of different numbers recommended on the 'Net....
FINALLY got it back rollin'. All new ball joints, new hub/bearing assemblies, new front brakes, new front struts! It drives like a brand new one! I am extremely pleased with the results (except for the cost), but I can't say that I would be anxious to tackle this kind of job again any time soon!!
I wanted to say again how much appreciate the help! Ford Truck Enthusiasts Forums comes through for me yet again!!
It's been a couple months, but I thought I'd just piggyback on this same thread. Everything we did to the Explorer seemed to be great. The thing handled and drove like new. Then we started having some weird things happen in the front end. Weird clunks, especially when backing up. I looked the thing over and it appears that the new upper ball joint on the driver's side has dislodged from the upper control arm. I'm going to jack it up and take a closer look to see exactly what's going on. I remember back to the stuff I read about pressing in ball joints on the 2002 Explorer. Different size ball joints and whatnot. I thought everything went the way it should when I reassembled everything. Something's definitely not right now however. Hopefully it's not too major....
