Rear brake hose for 75 Highboy
I haven't seen that issue before, have you had them run the number's for a 79 line and see its length? I am pretty sure all the threaded brake line connections are the same size for 73-79 at least?
But you never know with Ford. Worst case get a rear steel braided longer one (for a lifted truck) from Skyjacker, Summit or Jegs. Or if you have a local shop that can make them, go that even cheaper route.
I ran into this issue on my '75 crew. Ended up going with an extended length hose from JBG that worked well.
6" Extended Rear Axle Hose
Hope this helps.
Hope this helps.
Mojave922
05-30-2016 04:34 PM
DieHardChief
11-05-2013 01:17 PM
Keepin It Real
05-03-2007 11:08 PM
