351w MAF questions
351w MAF questions
I just bought a 1995 Bronco a few weeks ago. My plan is to drive it around for a while, see what I like and don't like, and then start modifying it. Right now I haven't driven it at all because I'm still waiting on the limited-slip rebuild kit to arrive. It seems to idle well but I've barely driven the thing.
It's California original 1995 Bronco so this means it's factory equipped with mass air, OBD-I, and a roller cam. It also has the E4OD transmission and it has about 160,000 miles on it.
I'm not looking for a ton of horsepower. I will never race it. I probably won't ever rev the motor past 4500. However, I would like gobs and gobs of low-end torque. It will see about 90/10 highway/offroad.
What parts do I need to start looking at? I don't have a set budget and I would like to do all the assembly myself. I wouldn't want to spend more than $3000 or so total although if I could build exactly what I wanted and it was $3500 it wouldn't be a sweat. I've never built a motor before but I know it's not rocket surgery. I'm not against building a 408W either.
So... suggestions?
So... suggestions?
on
Then that's what you should do. You don't need to go bonkers with the top end maybe just a little more cam and a little bigger heads, longtube headers and a 393 or 408 stroker kit and you got the better part of 500 ft/lbs of torque.
on
Cam suggestions would include the Comp 35-349-8, 35-512-8, 35-320-8. The stock heads are brutally small for a stock motor so even professional porting can only do so much, untouched GT40s are as good as ported stock heads, and something like an Edelbrock Performer is as good as ported GT40s. Optimal heads for 351 based stroker would be something like an AFR 205 just to put it in perspective, but heads that big will require a matching intake and much larger injectors and MAF meter since at that level the motor would be making a lot more power than a stock 460.
I think you'd be better off leaving the motor alone and just changing the gear ratio in the differentials. You'd get more bang for the buck and no worries about emissions tests. There are some minor things you could do though once this is done, like changing the rockers to full roller 1.7's, a drop in K&N filter, shorty's and a free-r flowing exhaust, you don't have mass-air EFI, so you're pretty limited as to engine upgrades without getting into the computer.
on
vogey
06-15-2017 07:33 AM
19-F250-78
17
03-23-2013 06:10 PM
BURNSTOUGHFORD
24
03-10-2011 03:18 PM
