brakes and power booster questions
getting ready to start on switching the axles over from the 79 one ton i bought to scrap out to my 78 250. was wondering the master cylinder and booster from the one ton be worth switching over also? also thinking of hydro boost. just trying to keep it simple. would the one ton stuff be worth swaping or will the 3/4 ton stuff work good with the different axles?
Either works fine. Hydro will have more braking power but is a bit more involved to swap over. F350 booster set up also works good....smaller booster for valve cover clearance but a will be longer than your original setup. The length didn't bother me any.
If what you have works good then I'd leave it unless you just havta upgrade.
KG Excursion
18
05-18-2017 08:29 PM
mouse777
07-25-2005 04:58 AM
Brian794x4
05-25-2005 01:15 AM
