That's the PCM fuse. Check to see if it's blown again. If so, disconnect the fuel filter heater (bottom left on the fuel bowl, single red/green wire flat terminal) and replace fuse again.
It was from autozone
Try a Ford or International part. FLAPS CPS are known to fail.
That's the PCM fuse. Check to see if it's blown again. If so, disconnect the fuel filter heater (bottom left on the fuel bowl, single red/green wire flat terminal) and replace fuse again. Try a Ford or International part. FLAPS CPS are known to fail.
it was not blown again. I guess I'll try to track down another CPS and see if that's what it is
If you're getting smoke while cranking now, it's a pretty safe bet the CPS is working. The PCM won't send a fuel delivery command signal to the IDM without seeing 100 RPMs of cranking speed. If the CPS is faulty, the PCM won't see a tach signal. If you have a spare one, it wouldn't hurt to throw it in, but a scan tool would probably be a better investment than a new CPS at this point.
Do y'all have a suggestion for a cheap yet good scan tool?
None of 'em are cheap. Choice depends primarily on what "format" you want -
* Dash gauge - Aeroforce (see above)
* "Hand held" scanner - Snap-On MT2500, with the K2a key and the right cable(s)
* Software on laptop/tablet/netbook - AutoEnginuity with Ford Enhanced bundle
