My first rebuild
Old 05-19-2015, 04:39 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Do you mean the heater fan. If so no It wasn't. A/c is getting fixed next week. . I saw the pillar pod reset which is connected to the stereo power. One other thing is the obd port is not mounted to the dash. I wonder if my wife kicked it without noticing. Not that that should cause a problem buuuut.
  #482
Old 05-20-2015, 07:20 AM
DIYMechanic's Avatar
DIYMechanic
DIYMechanic is offline
If the pillar gauges reset, the I think it's safe to say you lost ignition power. That means you likely have a loose connection somewhere up stream from there. I'd start by checking all the under hood ground and power connections.
  #483
Old 05-20-2015, 07:27 AM
MOOSE_MACHINE
I think your right Nate. I've got a couple of busy days ahead of me but I'm hoping to investigate this some more by the weekend
  #484
Old 05-20-2015, 02:28 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I agree with Nate. I assume you lost ignition power if the pillar gauges reset. Check the grounds (batteries to front cover and the small grounds that bolt to both inner fenders and the core support), battery cables, starter solenoid connections, and the firewall connection next to the PCM connection. That firewall connection connects to your under dash harness and if that came loose somehow it would cause everything in the cab to lose power.
  #485
Old 05-20-2015, 05:51 PM
MOOSE_MACHINE
Sounds good. I'll see what I find. I'm hoping to take a skid steer up to my dads place next week. It's about 5 hours away so I should know if I find it by then.
  #486
Old 05-17-2016, 11:27 PM
MOOSE_MACHINE
Holy cow I've been busy. I bought oil and filters most likely 6 weeks ago. Not done yet, plus my brakes went out about 2 weeks ago, not fixed yet. With planting lately and getting the crops off and all the break downs I've had this year I've had no time. On another note I've probably only put 50 miles on my truck in the last 6 weeks so I guess it's not to bad lol
  #487
Old 05-17-2016, 11:30 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
I was wondering where you were, don't work too hard!
  #488
Old 05-17-2016, 11:40 PM
nateairman's Avatar
nateairman
nateairman is offline
Hi Nick!
Chilliwack sounds like a rough town when listening to the CBC in my morning commute 😉
  #489
Old 05-18-2016, 12:29 PM
MOOSE_MACHINE
too late lol. Hopefully things start to slow down now
Originally Posted by nateairman
Hi Nick!
It is getting pretty bad around hee lately
lincky92
Missouri Chapter
08-25-2019 02:14 PM
427 fordman
244
05-09-2019 07:31 PM
Anderson80
11-13-2018 10:50 AM
Millermadness11
48
09-09-2015 12:44 AM
yellow truck
03-02-2011 09:58 PM
Quick Reply: My first rebuild
