My first rebuild
Old 06-30-2014, 09:09 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
Charge the batteries in that camera!
  #77
Old 06-30-2014, 09:32 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
It's like Christmas when you were a kid isn't it Nick! LOL!!.........except now we have to buy our own presents
  #78
Old 07-02-2014, 03:40 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
MOOSE_MACHINE is offline
Exactly. Except it's my wife crying and me Smiling.
  #79
Old 07-02-2014, 04:19 PM
oldbird1965
I always said, 'she'll get over it!'
  #80
Old 07-02-2014, 06:16 PM
MOOSE_MACHINE
Easiest way I've found to deal with it is take her camping. We took the TT to a nice little lake not far from home with the kayaks and bicycles and enjoyed the last few days with the kids. Unfortunately I have to do brakes on the yukon and repair a farm gate now. The yukon pulled the TT great but I will be glad when my truck is on the road for that task
  #81
Old 07-04-2014, 10:30 PM
MOOSE_MACHINE
The machinist just called me. The motor is done. He still has to do the intake valve seats but I can start on the short block. I will try to get it picked up tomorrow but I don't know how much time I will have for it though cause I just pulled the trailer to a nice little lake. I figured I would get one more trip in before I got the motor back but I guessed wrong
  #82
Old 07-05-2014, 05:25 AM
427 fordman's Avatar
427 fordman
427 fordman is online now
Sounds good Nick. Time to go to work!
  #83
Old 07-05-2014, 06:03 AM
ReBilld's Avatar
ReBilld
ReBilld is offline
When I rebuild the one I tore down the other night, I plan on painting the block and heads something other than black so it will be easier to spot leaks. Something like Ford blue, Ford gray, or the one I'm going with is Ford red. Just something to think about if you haven't already
  #84
Old 07-05-2014, 10:46 AM
MOOSE_MACHINE
i kinda like the idea of the black so I can't see the leaks
  #85
Old 07-05-2014, 07:33 PM
oldbird1965
Trouble is, the driveway sees it, LOL
  #86
Old 07-06-2014, 07:23 AM
MOOSE_MACHINE
Haha. That is true Glenn. I park on gravel so it doesn't matter as much but it is nice to be able to park on someone else's driveway and not have to worry about it.
I pulled out the injector cups late last night. The riff raff tool worked quite well but I could imagine it being a bit of a challenge inside the truck. I'm planning on cleaning up the holes and installing new cups this am
  #87
Old 07-06-2014, 07:39 AM
oldbird1965
I didn't realize the cups were that deep. How does the tool actually grab the cup to pull it out?
  #88
Old 07-06-2014, 07:57 AM
MOOSE_MACHINE
The idea of it would be like a 3/4" fine thread pipe fitting with a bolt welded to it. The tapered thread wedges it's way into the brass as you thread the bolt in and the nut is used to pull the cup out.
  #89
Old 07-06-2014, 02:18 PM
MOOSE_MACHINE
I finished the cup replacement this morning. Hopefully they seal up properly. All in all I would say that cleaning out the old retaining compound was probably the hardest part of the job.
Here is a pick of the cup puller Glenn
I used some wire brushes on a drill to clean the bores
After the wire brush I used compressed air to blow them out
Before installing the new cup I cleaned them with wax and grease remover. Sorry I don't have any pics of the retaining compound on them
It took two tries on the first cup because I don't realize how far to press it in. Shining a light from the bottom of the head helped to get it figured out but the only way I can describe it is tighten till snug and keep going till tight
The finished product
All ready for rosewoods stage 2's
All in all the kit is very well put together and I would recommend it to anyone. It comes with almost everything you need except the cleaning products
  #90
Old 07-06-2014, 04:58 PM
oldbird1965
If the motor is in the truck, how would you clean the hole out without getting stuff inside the motor?
Quick Reply: My first rebuild
