New rig, tow capacity question...
So I just picked up a 97 F350 7.5L gasser, dump body. What I have found for specs is:
GVWR: 11,000 Lbs
GCWR: 16,000 Lbs
Towing capacity: 7,300 Lbs
So the towing capacity is:
16,000 Lbs - Truck Wt (which cannot exceed 11,000 Lbs) = Towing Wt (which cannot exceed 7,300 Lbs)
Both the 16,000 Lbs and 7,300 Lbs limits seem low to me, have I got the #'s correct?
GVWR: 11,000 Lbs
GCWR: 16,000 Lbs
VIN Decoder - Ford F150 Forum - Community of Ford Truck Fans
on
You need to figure out what axle ratio it has, there is an axle code on the decal on the drivers door pillar? You will notice there are a range of numbers next to GCWR, those numbers correspond to the axle ratio.. higher ratio getting a higher tow rating. If your truck has one of the superduty ratios which is very likely it could have a tow rating as high as 20k with a gross combined rating as high as 26k. I'm getting these numbers from an owners manual BTW.
gfalin1959
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
06-12-2014 06:25 PM
Pete Roberts
26
02-14-2011 03:55 PM
