94 f150 towbar
Specs:
<table class="specificationsTable"><tbody><tr><th class="">Engine</th><td class="white">4.9L </td><td class="yellow">
</td><td class="last">
</td> </tr> <tr> <th class="">Drive</th><td class="white">4WD</td><td class="yellow">
</td> </tr> <tr> <th class="">Transmission</th><td class="white">5-Speed Manual</td><td class="yellow">
</td> </tr> <tr> <th class="">Cylinders</th><td class="white">6 Cylinders</td><td class="yellow">
</td> </tr> <tr> <th class="">Horsepower</th><td class="white">145 HP</td><td class="yellow">
</td> </tr> <tr> <th class="">Torque</th><td class="white">265 @2000 </td><td class="yellow">
</td> </tr> <tr> <th class="">Overall Length</th><td class="white">197.1" </td><td class="yellow">
</td> </tr> <tr> <th class="">Height</th><td class="white"> 70</td><td class="yellow">
</td> </tr> <tr> <th class="">Width</th><td class="white"> 79</td><td class="yellow">
</td> </tr> <tr> <th class="">Curb Weight</th><td class="white">3896 lbs.</td><td class="yellow">
</td> </tr> <tr> <th class="">Cargo Capacity</th><td class="white">N/R</td><td class="yellow">
</td> </tr> <tr> <th class="">Seating Capacity</th><td class="white">3/3</td><td class="yellow">
</td> </tr> <tr> <th class="">Payload Capacity</th><td class="white">2070 lbs. </td><td class="yellow">
</td> </tr> <tr> <th class="closeborder fir">Towing Capacity</th><td class="closeborder whi">0/2200 lbs. </td><td class="closeborder yel">
</td><td class="closeborder las">
</td> </tr> </tbody> </table>
I wouldn't use a Tow Bar anyway, they're illegal in some states. Use a tow dolly instead and you should be fine with the weight.
I did find a truck dolly it was wider then car dolly
we did get back yesterday only trouble could not get car all way on top dolly so
I had drive doll down hill so ramp touch ground
guy on tractor with bucket on it push the car on ramp. so got home
had another guy tow rope on back end car pulled it off. thanks
beanstock2
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
17
11-29-2015 03:43 AM
gfalin1959
06-12-2014 06:25 PM
UpNorth1
05-06-2014 08:38 AM
95_4x4_jay
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
11-30-2005 06:20 PM
