Yeah, any time there is a stumbling issue, the first thing I say is to check that fuel pressure! Diagnosing a problem can be a pain, but I would rather have a headache than a wallet ache from just chasing symptoms by throwing parts at it.
Changed the relay, didn't fix the problem. I guess it is the pump unless the fuel pressure regulator could be the culprit? And the relay is behind the radio by the way.
By behind the radio do you mean in dash or back of engine?
