1997 f150 4.6, misfire on both #1 and #8
Hello everyone, I've got a 97 f150 that has randomly started missing over the last month. It has started to get more frequent and codes are showing a misfire on both cylinder 1 and 8. Both of these cylinders run off the same coil pack. I'm thinking its the coil, what do you guys think? The plugs and wires, motocraft, have about 3k on them and the truck runs great otherwise. I just don't know how common a coil would cause this or if they would act intermittent like this.
Thank you!
Thank you!
It wasy understanding that #1 was passenger side and #8 is driver side.
Part 1 -How to Test the 2 Coil Packs (Ford 4.6L, 5.4L)
Ya I knew which cylinders 1 and 8 were, I just initially thought they were on the same coil pack. I retraced them and that's not the case.
Thanks nojoke327, that article helped. I did find a bad wire on number 8, replaced it and its running fine. Not sure why that would have caused a misfire code for number 1 though. I reset the codes and will see if it acts up again.
Thanks
Thanks
Thanks
Thanks
