6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 Filter Minder
Old 04-29-2014, 12:40 PM
Movingsolution's Avatar
Movingsolution
Movingsolution is offline
6.4 Filter Minder
I feel like every time I open my hood my filter minder is set to the "replace filter" and I have to reset it. Recently cleaned my filter. Noticed I have the old part number (already put it back on truck) and saw a few threads on the web referencing a new part number (8C3Z9N622A). Does this minder do anything other than visually tell you that your filter needs replacing or will it effect performance. 2008 6.4 - Early model as it seems they changed to a new filter minder according to the Google. I am tuned and deleted running an S&B intake.
Thanks.
Old 04-29-2014, 03:32 PM
senix's Avatar
senix
senix is offline
Received 1,418 Likes on 1,013 Posts
your problem has to do with the S and B...not fords part.
Old 04-29-2014, 06:52 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
When it gets "bad" enough you'll get a light on the dash. For whatever reason when I run a Wix filter it trips the light in a few thousand miles, can reset and it trips almost immediately. Is also an early '08.
Old 04-29-2014, 08:30 PM
Movingsolution
Any particular reason? Hadn't seen anyone else with that issue.
Old 04-30-2014, 05:04 AM
senix's Avatar
senix
senix is offline
Filter is not moving enough air for the system. If you have the stock airbox and filter then put it back on and see.
Old 05-04-2014, 10:13 PM
langballs's Avatar
langballs
langballs is offline
My filter minder was tripping easily as well. Tested it with a Mityvac and it only needed 5 in Hg vacuum. Too sensitive. Just unhooked and plugged hole. Been meaning to put a mechanical type that registers restriction.
SC_Dave
08-16-2015 07:01 AM
whporwil
08-12-2010 06:46 AM
squaredancer
03-13-2009 11:01 AM
Iceman31
23
03-09-2007 11:07 AM
Quick Reply: 6.4 Filter Minder
