running and fuel tank issues
First I'm an old time mechanic been doing this for 28 yes but this 87 F150 has got me a little annoyed, she has some issues one is that first I was having fuel issues between both tanks, I've put in new pumps tank and rail, new tank splitter inline valve, fuel filter and up dated the switch according to Ford TSB for fuel tank issues from switching from one tank to other. Both relays are new all wiring is good new plug on rear tank, with old system before all updates only front tank would work , now with all updates only rear tank works, been that way now for a while done beating head against wall.
Second the top hose collapsed from T/stat repaired that now I have the old surge and want to die syndrome, has new plugs, cap, rotor, coil, egr is good been checked, now bought IAC, TPS, MAP, all vac hoses good will see if that does it and has hi mileage but not issue, just need some other ideas before I put dynamite in truck.
fordsuperduty250
09-20-2011 01:04 PM
Penrider
05-10-2010 03:02 PM
mrlightrail
07-09-2008 02:42 AM
