Ongoing 2002 F250 Build 5.4L -> 7.3L Swap
#427
#429
Well good and bad news today. I guess I'll start with the good even though the bad outweighs it unfortunately.
The grind up front seems to be gone it was a brake pad that was lodged sideways and just disintegrating. Got is swamped out along with the rotor and all is good.
Time for the bad, went for a test drive to make sure the grind was gone and went to stop and blew the drivers side rear caliper apart and lost all my fluid. Also when I stopped to investigate I pulled into my driveway and saw a nice waterfall of oil pouring off the backside of the engine.
Investigation will start tomorrow to track down the leak and a new caliper.
#430
#431
I tried to track down the leak before it got dark but the best grids I can come up with the the ebpv actuator. It looks like it is were the leak came from. I started the truck and let it idle and revved it up a bit and it wouldn't leak for me. But when I look in that area I'm pretty sure that's were it came from but not positive as it was probably a good half quart or two that came out. Can that rod leak that much that fast?
#432
#433
Ok so both rear sides got new brackets and calipers today. Nice and shinny!
As far as the leak goes I cannot make it happen again but what I did do is unplug the ebpv solenoid wiring so that it can't think that it needs to open and shouldn't send any oil through. This is the only thing I can think of. I drove it for about 30 min and couldn't get it to leak like it did.
#434
Need to install new traction bars. (may need new ubolts)
Need to replace lower radiator hose.
Need to replace thermostat and sensor
Need to replace 3 studs on front passenger hub
Need to cap off the EBPV actuator on pedestal
Need to buy the overboost fooler
Need to buy the F6 Chip (Need input on what tunes)
#435
