Air pump removal, pulley swap
Old 04-21-2014, 08:45 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
I'd like to replace my air pump with just a pulley to eliminate it or can I just gut the insides of mine. It makes a weird sound on startup and I think while driving.
Old 04-22-2014, 07:00 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
I simply removed it all together, shorter belt and plugged the holes in heads. This was on a 76 302ci.
Old 04-22-2014, 06:31 PM
jimbbski's Avatar
jimbbski
jimbbski is offline
Most likely you had an engine with multi "V" belts which made it easier but if the poster has a single multi-groove belt it's not that easy.
Yes replacing the pump with a dummy pulley should work fine but it may be possible, as the second poster mentioned, to just use a shorter belt. But not always.
Old 04-22-2014, 07:44 PM
73 ford guy
Ended up running a 90.5" belt not a 94" or 97"!!.
Didn't even pull air pump! Removed bottom two bolts and loosened too pivot bolt, moved out of way, and cranked bolt down hard. Put other bolts back in their holes and if there was an issue I'll keep old belt behind seat and bolt it all back up with a few wrenches.
Old 04-23-2014, 04:41 PM
baddad457's Avatar
baddad457
baddad457 is offline
The idler pulleys made for Stangs also bolts right up to the 5.0 and 5.8 brackets to replace the smog pump. My 96 E150 van never came with a smog pump, it's got a factory bypass idler pulley.
loseboltssinkships
09-29-2016 05:55 PM
VI250
12-11-2012 02:00 PM
strokinout
03-06-2011 11:45 AM
trotsky13
28
11-29-2009 07:04 PM
Skandocious
26
07-08-2007 07:33 PM
Quick Reply: Air pump removal, pulley swap
