Air pump removal, pulley swap
Most likely you had an engine with multi "V" belts which made it easier but if the poster has a single multi-groove belt it's not that easy.
Yes replacing the pump with a dummy pulley should work fine but it may be possible, as the second poster mentioned, to just use a shorter belt. But not always.
Ended up running a 90.5" belt not a 94" or 97"!!.
Didn't even pull air pump! Removed bottom two bolts and loosened too pivot bolt, moved out of way, and cranked bolt down hard. Put other bolts back in their holes and if there was an issue I'll keep old belt behind seat and bolt it all back up with a few wrenches.
loseboltssinkships
09-29-2016 05:55 PM
VI250
12-11-2012 02:00 PM
trotsky13
28
11-29-2009 07:04 PM
Skandocious
26
07-08-2007 07:33 PM
