Thinking of trading my X :( thoughts on this F250 diesel?
#32
What's wrong with these guys? Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
You could expand your family not lose your family.
#33
Apocalypse made the right decision keeping what he has - regardless - because keeping the Ex is economically the best option no matter how you slice it.
#34
I suspect coolant leaking into the intake from holes in egr cooler contributed to a few blown head gaskets. Not sure studs could've held the gaskets then either.
I had to replace a blown head gasket on my tahoe, twice, one each time. Luckily, with FTE's knowledge base, every repair makes my Ex better than original. Never had this experience before. :-)
Sent from my Sprint PC36100 using IB AutoGroup
#35
#38
#39
your 5.4 2v is essentially the same externally as a 5.4 2v out of the Lightning or HD F-150
just saying, there is another +100 HP that can be bolted on with relatively little work. there are quite a few walkthroughs on how to slap the blower/intake off a HD or L onto a normal 5.4 2v. and since many of the HD/L guys upgrade their blowers...you can get the blower quite cheap
#40
Here's a list of what's needed for converting a N/A 5.4L engine to a S/C Lightning clone. http://www.madenterprise.com/scparts.htm
Stewart
#42
For the 2V 5.4L engines, it's a little more than just slapping a S/C on the engine. Some of the necessary items are no longer available, so a person would have to overcome that hurdle too.
I'm not saying it can't be done, it's just since the tech is old (the last Lightnings were made 10 years ago), it would be a challenge.
Stewart
Stewart
#44
#45
