Thinking of trading my X :( thoughts on this F250 diesel?
  #31
Old 04-18-2014, 02:46 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
I'm totally out, he seems flaky and I have a lot of time invested in my truck Plus I loose this family if I trade the X off
  #32
Old 04-18-2014, 02:55 PM
mecdac's Avatar
mecdac
mecdac is offline
What's wrong with these guys? Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
You could expand your family not lose your family.
  #33
Old 04-18-2014, 04:18 PM
Magnus E's Avatar
Magnus E
Magnus E is offline
Originally Posted by Clay H
Yep, and the only one. And you know for sure it was a blow head gasket causing the degas bottle to puke and not just the weak cap?
Yep - tried new cap first. After HG and studs (trust me I tried everything else first) - no more problems. Let's end this unrelated to the OPs post. We can argue this back and forth until we are blue in the face.
Apocalypse made the right decision keeping what he has - regardless - because keeping the Ex is economically the best option no matter how you slice it.
  #34
Old 04-18-2014, 04:49 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
I dont know of a single one. To say "many" is a stretch. Of course any engine can have a failed HG for whatever reason but the #1 cause of 6.0 head gasket failure is excessive cylinder pressure from custom tunes. Factory tuning simply can not lift a head.
Trading for another used vehicle often just changes the faults you have. Glad the OP is keeping it..
I suspect coolant leaking into the intake from holes in egr cooler contributed to a few blown head gaskets. Not sure studs could've held the gaskets then either.
I had to replace a blown head gasket on my tahoe, twice, one each time. Luckily, with FTE's knowledge base, every repair makes my Ex better than original. Never had this experience before. :-)
Sent from my Sprint PC36100 using IB AutoGroup
  #35
Old 04-18-2014, 04:51 PM
Apocalypse's Avatar
Apocalypse
Couldn't agree more
  #36
Old 04-18-2014, 06:34 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Now buy some new parts for your X and love it.
  #37
Old 04-18-2014, 08:02 PM
jayjjcc's Avatar
jayjjcc
jayjjcc is offline
You say you're limited in what you can do for work on the 5.4 but were thinking about trading it for a 6.0??
  #38
Old 04-18-2014, 09:26 PM
Apocalypse's Avatar
Apocalypse
Well a 4X4 truck, the lift options are there where they are not on my 2wd X and there is no HP upgrades left on my 5.4 to speak of.
  #39
Old 04-19-2014, 01:01 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
your 5.4 2v is essentially the same externally as a 5.4 2v out of the Lightning or HD F-150
just saying, there is another +100 HP that can be bolted on with relatively little work. there are quite a few walkthroughs on how to slap the blower/intake off a HD or L onto a normal 5.4 2v. and since many of the HD/L guys upgrade their blowers...you can get the blower quite cheap
  #40
Old 04-19-2014, 01:22 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
It's a little more than "relatively little" but then again, it depends on a persons individual definition of "relatively little."
Here's a list of what's needed for converting a N/A 5.4L engine to a S/C Lightning clone. http://www.madenterprise.com/scparts.htm
Stewart
  #41
Old 04-19-2014, 01:25 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
I do all of my own stunts...so to me it's a weekend conversion. I remember all the "fun" I had installing the RoushCharger on my 5.4 3v...miss that truck!
  #42
Old 04-19-2014, 02:08 AM
Stewart_H's Avatar
Stewart_H
For the 2V 5.4L engines, it's a little more than just slapping a S/C on the engine. Some of the necessary items are no longer available, so a person would have to overcome that hurdle too.
I'm not saying it can't be done, it's just since the tech is old (the last Lightnings were made 10 years ago), it would be a challenge.
Stewart
  #43
Old 04-19-2014, 03:29 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Since your keeping the Excursion and going to be using it to work the gears and a truetrac or locker in the rear are a great plan. Do you have an aftermarket y pipe?
  #44
Old 04-19-2014, 08:39 AM
Apocalypse's Avatar
Apocalypse
That was the first and best upgrade thus far I think I need to update my signature...
  #45
Old 05-11-2014, 05:14 AM
icentropy's Avatar
icentropy
icentropy is offline
Y pipe huh? I've been thinking about doing some light cheap performance mods to the v10 now that it's running right, did you notice a big difference?
Quick Reply: Thinking of trading my X :( thoughts on this F250 diesel?
