Front Suspension Bang
Hey alll starting having a problem with the front suspension on my 01 excursion. When you go over a incline I am getting a big bang in the front suspension also when you turn the steering wheel to the middle it has a jerk right before its in the straight position.
I have new wheel bearings and new locking hubs coming, this problem still happens without the hubs in. Could it be a front axel or U joint but it happens with the 4x4 dissengaged.
Thanks for the input
Brian Felts
Brian Felts
I agree with Mach1394 check the ball joints, also check the front sway bar links and sway bar bushings and the front shocks. Mine was make some noises and I thought it was just my sway bar bushings when I got it last year. My sway bar bushings are worn out and allowing the bar to move around but my front lower shock mounts where loose. Previous owner stated his son n law was a ford mechanic and replaced the front shocks. Well he is not much of a mechanic because they were loose and he wrecked the special nuts that have the locking tap to hold nut so you can tighten them up & rounded off the nut. I replaced the nuts with locking nuts & most of the noise is gone now just the sway bar bushings and links need replacement. Going to wait on them and do it when I do my X/B spring swap in next few weeks.
Randy
Randy
on
Looseness or anything abnormally felt in the steering wheel like crunching, crackling, etc and steering not returning to center but this is only after everything else is in good working order. Also look for leaks.
This is what I found, the drivers side axel (with the locking hubs out) I began to turn the axel and found it seems to be turning out of round. I locked a set of vice grips on the tip of the axel and spun it and it got real tight didn't want to turn and I noticed the end of the axel would dip as I turn it. Went to the passenger side and turned it and it was smooth and stayed straight.
Do I need new U joints in the axel or is there a guide in there that has went bad. Please note I have a brand new wheel bearing on that side.
Brian Felts
Brian Felts
on
Brian Felts
Brian Felts
Brian Felts
Brian Felts
on
https://www.ford-trucks.com/forums/1...l#post13712449
01powerstroke01
36
04-08-2008 11:29 PM
