Did my transmission die?
Ok, I was driving down the interstate in my 2002 Ford Escape XLT 4X4 and I noticed my rpm's reved to about 5000 from my cruising rpm of 2200 and it was as if it went into neutral. I coasted with engine running fine to the right shoulder and called a tow truck to the nearest dealer. No reverse, D, 2 or 1 only Park that worked. Any ideas?
I wanted to add a few things I forgot:
I had no indication that there was a problem.
No lights on dash whatsoever or pending trouble.
Checked fluid, was clean and full (just did a system
Drain and fill with Mercon ATF less than 2000 miles ago)
60,000 miles on REMAN transmission installed by
Ford dealer.
Thanks for any ideas or solutions.
Ford dealer.
So I might be able to get by without a new transmission? Just pump or shaft repair?
The amount of labor to replace the transmission is a little less that cracking it open for diagnosis. By the time you crack it open, you might as well rebuild or replace the thing and get a warranty.
You're probably looking at $3,000 to $3,500 for a re-manufactured transmission with a warranty which may exceed the value of the vehicle. You can probably get by with half that for a used transmission, but you won't get much, if anything, of a warranty. If the replacement transmission breaks next week, you'll still own a busted 2002 Escape with a bad transmission and you'll be out whatever money you put into it.
Unlikely. Most shops wouldn't bother doing a piece-part repair and warranty it.
You might do better having your transmission worked on. When a shop does the job, they don't have to account for covering the cost of any 'hard parts' that need replacement when they quote the job unless you unit needs them. A re-man from a factory has the hard parts cost spread over all their units, so it likely will be more pricey. If you only need a pump drive shaft, they can do a 'light' job on the rest of the unit. When I was at my Dads AAMCO, they offered three levels of repair, with more parts and warranty period as you increased price.
The oil pump is driven by a shaft that is sort of long and skinny. If that sheared or the grooves in either end wore and allowed slippage, you'd have the condition you describe. Problem is, I am pretty sure the shaft can only be replaced with the transmission removed and disassembled. I'd go local if you can find a reliable and reputable shop. Unless you travel or plan to move, you don't need a national warranty. IMO.
tom
tom
tom
tom
Thank you for the reply. Makes you wonder if it's worth it as long as the rest of the vehicle keeps up fine. Guess you would need to see what the kelly b book value is and take it from there. It puts you in a bind that you can't get much for a escape with a bad tranny either.
