99 f250 superduty,5.4,170k
OK, we've hit one of my buttons here.
I don't mean to call anyone out here, but anyone who tells you to replace a part without doing any testing is not doing you any favors. Don't waste your money throwing parts at the truck, hoping maybe you'll solve the issue by accident. Get your truck to a local auto parts store that does free vehicle scanning and ask them to pull your eror codes.
thanks much
I wont buy parts without codes being read .battery is new/ good.dont remember if cel came on or not...thanks for tip on checking fuel pressure. Truck has always run perfectly,was doing about 35 mph and it acted like a car running out of gas.had 1/2 tank....I just thought someone knew if these fuel pumps were known for going out at about that mileage...i ll try schrader valve thing and buy a code reader in next few days..go from there..thanks again to everyone for your time and help...out
99 250 superduty died
Read codes,scanner said " no codes stored" ,no help there.fuses and relays good,switched fuel pump relay with another identical one ,no help.did schrader valve thing got a dribble ,maybe 2 tbs..no great spurt of fuel.definitely not 50 lbs of pressure,maybe 5- 10 lbs pressure.....don't hear fuel pump when key is turned on....i'm guessing "fuel pump"...will update
