clutch time assistance please
Springs are probably from the DMF. Brake pad material sounds more like the clutch... While there is an internal clutch in the DMF, there is no way that would drop out in the truck, its buried in the center.
Although there are plastic pads on the ends of the springs that might look something like brake material if dirty and busted up? *shrug*
Either way, go SMF, its cheaper and more reliable.
I went through this last spring around this time. spent a lot of time pricing things out. smf is absolutely the way to go. I ordered the conversion kit from autozone for $385 it came with everything needed except fluids. It has worked fantastic. the clutch is better than it ever was before.
so i did the smf and new clutch. the gear chatter is very very loud. i filled through the top with 2 gallons of 30wt non detergent hearing that doing that would quiet the gear rollover noise. its got me wanting to go back to the dmf. how loud should it be? its loudest when stopped in neutral foot off clutch. depress clutch and its silent. get to about 1200 rpms and its silent.
