Fuel pressure gauge install question
I bought an Autometer 4763 gauge that didn't come with the correct fittings to plumb the sender into one of the extra ports on the back of the bowl. I went to the Ace hardware store right across the street and they didn't have anything (not surprised) and then Napa. They couldn't find a fitting to match either. He found that the plug threads are 7/16 20 tpi and the sender is 1/8" NPT. He suggested getting a 7/16 20tpi bolt, drilling it rifle-style, and then tapping it for a 1/8" NPT. The alternative, and what I ended up doing, was to use brass fittings to tee it off one of the supply lines to the heads. I ended up going that route but wanted to know if I should have looked harder for the right fitting.
Here's a pic of what I have now. I've test fit it, and it seems to work although I will need to insulate the hard lines because they rub due to the offset.
It's some kind of ORB, Riffraff has it.
Pressure Port Adapter - Straight 1/8 FNPT for Ford 7.3L (99-03) - GZ-13-001
Riff raff sells straight and 90 degree. Parker hydraulic stores usually have them as well
Pressure Port Adapter - 90 deg elbow x 1/8 FNPT for Ford 7.3L (99-03) - GZ-13-002
What you did will work to give you post filter pressure.
Why not use the test ports or whatever they are called on the side of the bowl toward the engine? There is a pre and post filter. I installed a 90 degree on the post filter port and it works great for the ISSPro sensor.
Guzzel's
Fuel Bowl Parts and O-rings - 1999-2003 Ford 7.3L
13-001 or 13-002
1/8" NPT pressure port adapter. Fits the pressure ports straight thread fitting located on the rear of the 99-03 Ford 7.3L Powerstroke fuel bowls for aftermarket fuel pressure gauges or to add a pressure test port to your fuel system.
13-001 or 13-002
Izzy351
56
05-24-2010 11:51 AM
kirkharrod
26
06-12-2009 12:58 PM
