Excursion Lift and Wheel/tire set
Hi ive got a factory 03 excursion 4x4 with the 6.8 v10. Its running 256/75/16 tires and theyre all worn out. Im going to replace them and definitly want to go bigger. I was thinking of going 305/70/r16 if i dont go with a lift or new wheels. Im on a 2000$ budget and was really wanting to go with 35's. What do yall recommend? I was looking at Khumo road venture MT KL71 and some 8 or 9 inch wide wheels. But Im lost as to what lift i should go with. Ive got about 500 left for spending on a lift.
<table class="productresults" height="146" cellpadding="0" cellspacing="0" width="1"><thead><tr><td colspan="4">
</td></tr></thead></table>
james do you have any pictures of what she looks like with 305/70/r16? And did you have to swap the wheels or does the factory 7" wides work? On the lift Im reading somethign about f250 and f350 lifts are 2" higher so am I correct in thinking i can just buy an f250 2" lift and be set with 4inches of lift on my ex?
Thanks for the info on the procomp thread going to go check it out now.
Glad to help! I got my whole suspension setup from him and he was a huge help. I told him up front that I probably couldn't afford the setup he recommended, but by the time i did all the research and after talking to him and listening to his recommendations and reasoning I decided to spend a little more and do it right. He went above and beyond to help me and is a great guy!
https://www.ford-trucks.com/forums/1...es-are-in.html
There are pictures of the EX's growth in this thread, from stock height with 305'sand factory wheels, to X codes and modded B code springs, to modded X code springs
Shop around on various sites for tires and wheels, I recently put a set of ATX Mojaves under the truck wrapped with 305/75/17 Nitto Terra Grapplers and lugs for $1900
Pretty sure the 06 leafs wont work. Not sure what an I code spring is...
I guess your best/easiest option would be the v/b setup. Some people mod the b code leafs with part of the Ex leafs for extra lift.
*S = 2C34-5310-AAB, 4,000 lb.
*T = 2C34-5310-ABB, 4,400 lb.
*U = 2C34-5310-ACB, 4,800 lb.
*V = 2C34-5310-ADB, 5,200 lb.
*W = 2C34-5310-AEA, 5,600 lb.
*X = 2C34-5310-AFA, 6,000 lb.
You'd also have to get answers from someone smarter than me as to whether or not the DRW C codes are a direct swap or not and if the C codes you're talking about are SRW or DRW.
