If I install a Manual choke do I remove the linkage?
Old 04-04-2014, 07:06 PM
ericford1984's Avatar
ericford1984
ericford1984 is offline
If I install a Manual choke do I remove the linkage? I have a carter 1 barrel and bending the linkage and fast idle set is not working out well. So I'm thinking of installing a manual choke. Truck is strictly a beach truck so it's used may to august. So like I said just curious if I do install a manual choke. Do I still need to set up the linkage. Or can that be removed.. Thank you
Old 04-04-2014, 10:28 PM
xlt4wd90's Avatar
xlt4wd90
xlt4wd90 is offline
I would remove the linkage to the automatic choke so it doesn't interfere with the cable for the manual choke.
Lightning23
23
03-08-2017 08:53 PM
avellaneda13
10-26-2016 01:53 PM
67FEranger
12-12-2012 03:28 PM
TGenolcyC66
12-26-2010 01:45 PM
sammycooks
04-04-2010 03:41 PM
Quick Reply: If I install a Manual choke do I remove the linkage?
