4R70E shifting trouble
need help, my 08 E250 with112mi started giving me trouble the other day,when i started to take off trans would hesitate then jump in gear and the trans makes a louder wine in park. so i read one of the post how to drain fluids including torque converter and filter too. refilled trans every thing was running good for one day now trans seems to start off in maybe second or third gear and the loud wine is back in park need suggestions what to do
Just a suggestion, if you are asking for help you should refrain from posting garbage like this.
Your transmission is the most complex mechanical component of your car, and most of us just don't understand them that well. Mark is a great resource, as would be someone with experience rebuilding and replacing these transmissions. But I'm neither, so adding idle speculation would probably not be helpful.
My wild guess would be that something either went wrong when you had it apart or you didn't correct the problem when you were replacing things.
Must be the weather huh?
Sent from my Telegraph using IB AutoGroup
Is your speedometer functioning ? One with a faulty PSOM will screw with the transmission's functions.
