I have decided to go with air bags....???
I have decided to go with air bags to get that low low look. I have build cars/trucks in the past and cut corners where i could and have never beed totally satisfied. So this time im going to build exactly what i want . I want a F100 that i can lay on the ground. MY QUESTION IS what front end should i go with if im going to air bag the front and back. My first thought is Mustang II and 4 link the back. Any suggestions???????????????
trucks 009 by bubbletop1962, on Flickr
I would think you are correct. I have a TCI Mustang II and 4 link, both with coil overs. Both very nice kits. Swap the coil overs for bags and you would be good to go. TCI and others offer their kits this way.
Sounds like a plan,
I am using the Fatman Mustang II Variant at the front and a Jag IRS at the rear. When you say lay on the ground, do you really mean that? As if so you may not get that far at the front with a standard MII kit. The lowest my front end goes to the ground is about 2 inches.
Two inches sounds good. Can you post a pic if yours all the way down. Thanks Chad
Sounds like a plan,
alan_scott
05-26-2013 09:10 PM
parkland
1999 to 2016 Super Duty
13
05-18-2012 10:45 AM
