How much oil does a Dodge 318 hold?
Old 07-03-2003, 01:11 PM
Stingray42's Avatar
Stingray42
Stingray42 is offline
5L?
We are doing an oil cahange on a 92 van and 5L only fills to the add line!
Thanks
Old 07-03-2003, 01:25 PM
AlabamaBronco's Avatar
AlabamaBronco
AlabamaBronco is offline
should be 5 quarts.....
Old 07-03-2003, 01:51 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Depends on how many miles since oil was added. Starts out at 5 quarts and rapidly works it way to 1 quart within 1000 miles.
Old 07-03-2003, 01:58 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
It sounds to me like you changed the filter at the same time (which is a good idea).
The filter may account for the extra quart.
Footnote: I'm a strong believer in keeping extra fluids in a vehicle's trunk or toolbox in case of unforseen losses. A quart or a pint of everything is enough for a well put together machine.
If you got it from a used car dealer - buy an oil well...
Old 07-03-2003, 05:54 PM
rebocardo's Avatar
rebocardo
rebocardo is offline
Most 318s take 5 quarts (owned and worked on 318s), except maybe vans because they have a different pan. You do have to run it, shut it off, and let it sit for 1/2 an hour to get an accurate read after doing an oil change.
