DTC Codes P0678 & P0675???
Thanks, My local shop is saying it can be the glow plugs or the glow plug control module. But they want somewhere around $125 in labor to do the work. Not sure if this is something I can tackle on my own or not.
Militant83 that's is correct, it could be either one and not ruling what it is the task in hand. My neighbor had to replace the passenger side glow plug harness. It can be expensive thru your local ford shop, but if don't have some mechanical skills to work on these trucks, then maybe you will have to use your local shops..
I can't figure out how to create a post, so I will try it here. I had a code P0678 (#8 glow plug), it wasn't causing a problem, I cleared the code and it would come back in about a month, now it comes back constantly so I decided to change out glow plugs 2,4,6,and 8 since I had the drivers side valve cover off. After reassembling now I get error codes P0678 and P0676 (plugs 6 & 8) well this sucks, now what? Is there something I should check before having to take off the valve cover again? Thanks in advance.
