F-250 Drive shaft E Brake
#46
Here is what I mean about the rivets. Notice in the picture one has a larger throat (not sure if that is the correct term.) The smaller one is the same size Jolly Roger Joe used. The larger one is the one I pulled from the box of misc rivets.
How big are your holes? I don't know if mine were drilled out when I removed the rivets (I don't think so) or something else.
#47
#49
#50
I just reversed the lining inside the band and installed it over the drum, then cranked it down. Looks fine, I think the wire backing is whats rivited or epoxyed to the band and the smooth surface contacts the surface of the brake drum. I think you were correct Jules, other wise it would be next to impossible to get a clean countersink in the mesh wire surface. I still have an inquiry into the seller. I will let you know what he says.
#51
Sounds good. If you choose to epoxy and rivet, I would epoxy first, while clamped to the drum to hold it in place then it won't move when you drill the holes. BUT then I had to use a drill bit and turn it by hand for the recess.
So you could also calmp it in place and mark all the rivet holes, then drill thru and recess with a drill press would be much nicer. Then apply epoxy and rivet quickly.
#53
Big thank you
Posting this to say thank you to everyone on this thread - without the info here I am sure my ebrake relining would of sat for a long time - Got the lining and rivets from McMaster-Carr and following Earl's guidance was able to pull it apart and put it back together today. I have been avoiding driving the truck much since I got it running without having the e-brake backup. Until I update the Master cylinder and separate the front and rear system the e-brake truly is the go to when any of the hydraulics let go.
While not nearly as pretty as Earls the brass rivets do look good against the black band.
Thanks again
JokerToo
1953 F250 with a LYB 317
Thanks again
JokerToo
#55
#56
Here is what the text portion of that book says:
I searched on PartsVoice.com and it says Green Sales has 8 of the springs.
Main
It also said Dennis Carpenter had one, but I didn't locate it...
I would guess you could locate the bolt at any hardware store. Probably the spring too.
Edit: But the bolt has a hole in it for the safety wire, so if you need that it might be more tricky.
Main
#58
I need to finish up some wiring and get a bed built or bought (I'm looking at some ford script beds, but they may be sold before I can see them.) Then I need to fix up my seat and I will be good for cruising. Boy, that makes it sound simple. I need to jot down that list and put it in front of me.
#59
I have three of these 56 F -Series projects all in pieces. 2 1/2 ton short boxes and a 250 long box with duallies and stacks. I can relate to the lack of motivation. When you look at the whole project, lack of motivation kicks in. When you like at one little project as a time, motivation kicks back in. Your emergency brake is a good example.
Get back in the game!
#60
Main
Main
