Sterling 10.5 SRW Gear Swap
I have a 1999 Sterling 10.5 SRW Rear End with stock open 3.73's and looking to install an Eaton/Detroit, etc with 4.88s or 5.13s (not decided yet).
Will an Eaton/Detroit, etc with 4.88/5.13 just drop in the 3.73 open carrier?
I know on some vehicles you have to change the carrier if going for larger gears AND/OR a locker/limited slip.
The rear is a spare that I have and I wanted to use it underneath a 5.8L Bronco with much lager tires. I would also use the D60 front axle as well. Both seem to be nice big upgrades from the Dana 44 front and 8.8 rear.
Jason302
07-20-2011 07:24 PM
Ford Stable
11-21-2008 05:57 PM
shotgun
04-15-2002 08:34 AM
