1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Front wheel bearings 02 F250 4x4 automatic
Old 03-30-2014, 01:35 PM
Dwayne Oxford's Avatar
Dwayne Oxford
Dwayne Oxford is offline
Not doing any good with search here. Need posts with no commas for front wheel bearings. Trying to see if anybody's got around the hi priced "assemblys".
Old 03-30-2014, 10:57 PM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Check the excursion tech folder for 1975stroppebaja and Guzzles 7.3 pages. Both have write ups and solid how to's with part numbers direct from Ford.
Tech folders with sticky's are a great place to check if your are not familiar with searching.
Old 03-31-2014, 02:51 PM
Dwayne Oxford
Thank you kindly,Sir Bentley! That was exacatly the good info we needed. May God bless and keep you and yours. Dwayne
Old 03-31-2014, 04:12 PM
Dwayne Oxford
How's the best way to thank 1975stroppebaja? Couldn't find a "username" search.
Old 04-02-2014, 12:39 AM
Bently_Coop
If you place the username in the search bar at the top it will populate some threads he has started.
Old 04-02-2014, 05:50 AM
jesse5's Avatar
jesse5
jesse5 is offline
Smile SKF or Timken Unit Bearings
You want to use SKF or Timken unit bearings as the lessor brands will not last as long.
stana1
07-06-2015 01:33 PM
Maximus172
10-11-2007 07:37 PM
DaleEO
S. California Chapter
10-09-2007 11:05 PM
david11690
11-24-2006 07:14 PM
nubwon
11-29-2004 04:42 PM
Quick Reply: Front wheel bearings 02 F250 4x4 automatic
