6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
whistling noise
Old 03-27-2014, 10:47 PM
lilrams09's Avatar
lilrams09
lilrams09 is offline
whistling noise
Guys not sure what think on this one. I have a whistle wine noise. It just started this I have no idea why our what caused it. I haven't drove the truck in about a week I thought it was a bake but it's not. It only does it when moving and it doesn't get much louder at any point. If I'm doing 5 mph or faster it will do it coasting or accelerating it doesn't matter.
Any idea here I'm lost as lost . Truck is deleted with innovative tunes.
thanks.
Old 03-28-2014, 05:11 AM
senix's Avatar
senix
senix is offline
Received 1,417 Likes on 1,012 Posts
sure you are not hearing the turbo? If this is new then it might be your downpipe is leaking a little. Check all of your exhaust components for soot.
Assuming you are hearing it from the engine bay?
Old 03-28-2014, 06:44 AM
lilrams09's Avatar
lilrams09
No defiantly not the turbo, i guess the word squeaking or squealing might be a better way to describe the sound.
it does not do it all the time it started on my way to work today. And just quit after 5 minutes!
I'm thinking its in the drive line?
Old 03-28-2014, 07:54 AM
senix's Avatar
senix
senix is offline
Brakes is where I would start based upon the new information.
Start with the fronts as they wear quicker. It might be getting close. I'd recommend pulling the wheel off at least one side and inspecting the pads for wear.
You can pretty much do that without removing the calipers.
Old 03-28-2014, 08:29 AM
lilrams09's Avatar
lilrams09
i was thinking it could be that but it doesn't seem to be i just put brand new EBC brakes on it all the way around, aprox 1,000 Miles ago.
Could it be a Ujoint? and why would it go away and come back at random times.
I took a video but can't seem to get it to upload, is there anyway i could email you the video? if so PM your address and i'll send it over
Old 03-28-2014, 09:50 AM
senix's Avatar
senix
senix is offline
PM sent. ujoints usually act differently then what you are indicating.
Will listen and see if I can tell.
Old 04-14-2014, 07:24 PM
Bruce P's Avatar
Bruce P
Bruce P is offline
Whistle
I had the same problem and it was a partially stuck opne ERG value that whistled like a train when accelerating
Ford repair under warranty + Part $95 and labour $470 to get at the valve Here in Canada
Bruce
pascalhorse
13
10-24-2020 08:17 AM
RedDevil460
03-11-2015 02:13 PM
shark1979
04-05-2013 09:29 AM
Dyllan78
03-30-2011 08:02 AM
BigJake34452
03-08-2010 09:56 PM
Quick Reply: whistling noise
