Trouble with my 1974 F250
Ok hopefully someone can help, here is the story.
my truck did start super easy but over the few days it would sit the battery would run down and need a boost but then it would start right up first turn so yesterday after putting the new exhaust on i took it to the store (bout a mile away) pulled in filled her up and went inside to get a snack and then came out to a no start so i figured it was the battery and called my friend for a jump which did nothing so we pulled the battery took it and charged it and still nothing so we push started it (4speed truck) drove it home pulled the started to have it check, pulled the alternator also and got it checked, both checked out just fine but for good measure i replaced both with new, get home same issue
then replaced the cables from the solenoid to the starter and then the solenoid and then the cables to the solenoid to battery and then the solenoid and still the same no start issue prevails....im at a loss please help
Welcome to FTE.
Did you have the battery checked also?
Did you replace the battery ground cable too? If not, check both ends of the cable. Be sure that the ground is connected to a clean point on the engine block. Clean the terminal end of the cable and the battery terminal too. Be sure ALL connections are clean and tight.
I suspect a bad ground, a common problem with a "no start".
Welcome to FTE.
connections are clean and tight everywhere else.
hope its the ground cuz im at a loss if its not
Ignition switch is brand new, i just replaced the ground cable from the battery to the block and though it didn't start it did very slowly turn the engine, so i'm thinking it could be the battery though on the multimeter it reads 12.65v but on the charger it shows as 25% charged so i'm a little baffled but i am gonna go get a load tester and re-test the battery and i am thinking about adding a secondary ground strap from the block to the frame just for good measure
clicking sound like a dead battery
Sounds like something is slowly draining the battery. A wire missing some insulation, shorting to ground? A dead cell (or two)? Have you checked each cell for its specific gravity? Filled each cell with distilled water before charging it?
The solenoid needs to be grounded properly, too, as well as good, clean, tight connections.
A good battery wouldn't lose it's charge just sitting for a few days without some kind of load draining it.
My truck sat for over a week with the temperature in low teens during the day and single (and below 0) digits at night, and started up (but a little labored) when I could get out to run it.
I haven't checked the battery water levels, though i have chased and replaced almost all wires as i too thought it was a wire grounding out causing it to die so quickly, right now the battery tested at 12.41 volts but it only had 375cca instead of the 650cca it should have, also the truck has now started but after driving it around the block and shutting it off the battery wouldn't turn it over so i suspect bad battery right now and will know shortly if that is the case
Battery is 5yrs old now and I do also think battery issue, wish i had gone here first before replacing the starter and the solenoind and all the cables.....time consuming and not exactly cheap but the batt. read 12.65v and nothing was happening so i just kept going down the line only to return to the battery
