85 f250 lift kit problums
I recently put a 4 inch rough country lift on my 85 f250, the first problum is the u bolts for the back were to long so they didnt have enough thread, the other prublum is the drive shaft is now hitting the cross member, i heard this was a problum for the 6 inch lift but is this normal for a 4?, last but least, my front end is messed up it seems like the leafs are two big compared to the drop brackets and it angles my tires, and gets really bad when i back up, i have a dana 50 if that helps, has anybody had any of these problums, and what have you done, im sure im not the first to buy this rc lift kit. Thanks
On the rear, did you use the original blocks AND the lift blocks? You should have if you didn't.
jmm
05-08-2010 05:00 PM
stangman516
12-21-2007 07:06 AM
