Kill switch on a 80-86 Bullnose??
#46
#47
#48
#49
Only works if you have an electric fuel pump. Or, have other diabolical ideas. Like maybe a relay that shorts the coil's negative side to ground? Someone might think to power the relay with a jumper from the solenoid and then jump the solenoid to start the engine. But if you take the negative side of the coil to ground the engine won't run. And the only way to find that is with a meter and know what you are looking for. All you have to do is take the tach signal to ground and the engine shuts down immediately - I tried it recently.
#50
Fleetwood271
06-15-2019 11:12 AM
F1Hunter
41
01-02-2016 03:38 PM
Gary Lewis
68
10-10-2013 08:42 PM
