Need help with heat/AC switch
My dad has a 79 bronco and the switch for the vent selector is not connected. The blower motor is always on with the key. the bottom left to right switch that turns on the blower motor is not connected to the mechanical wire, like those found on bicycle brakes, and is nowhere to be found. I need to know where it connects to so that i may see if is still attached to the other end. All help is greatly appreciated!!!!
The bottom wide sliding switch that controls the AC, Vents, and Blower motor on/off
Can post pics later if you wanna see it!
spook222
08-11-2016 10:32 AM
