Diesel Starts Rough Some Mornings
I have a 1992 F350 with the 7.3 diesel in it. I bought it a few months back and had the oil and some fuel lines changed. I only drive it a few miles a day. Lately if I let it sit for more than a day or two it starts really rough and dies. If I press on the accelerator immediately and keep it between 500-1000 RPMs right as I start it, it does not die and starts to run normal in 10-20 seconds or so. I live in Northern CA (no snow in my city) and it does not get too cold. I am a rookie with diesels and really appreciate the help.
While this could be an issue of air intrusion, I suspect you've got one or two leaking injectors. Overnight, they leak down a bit, and it takes a few seconds of running to build up pressure again.
I had this before, and it got to the point where it was not firing on all cyls for the first 30s... go out there and find the injector which wasn't firing. I replaced it with another I had, and the problem got instantly better.
rocketma1n
03-18-2014 10:22 AM
BlackJeep
22
10-21-2008 03:08 PM
deckpros
12-29-2006 11:25 AM
