Glass Measurements
Glass Measurements
Hey guys,
I need to replace the window glass in my 1948 F5. I have the windshield, one piece of vent glass, and one piece of window glass. I do not have the rear glass. I am planning on having a glass shop make a laminated piece for the rear but was wondering if there is a diagram that shows the glass measurements. I searched this forum but I did not find it after reviewing about 50 posts.
Also any tips on how to get the vent glass out the frame would be appreciated. It appears fused with the metal.
Thanks in advance for your help.
Without a pattern, I would think the best route would be to buy a ready cut glass from one of the several parts vendors. Shipping will be a few dollars but at least you know it will fit. Don't forget, the seals should be replaced with the glass. Sixty five plus YO rubber seals can't be very pliable. Try spreading the frame slightly, top to bottom to remove the vent glass.
Great, another F4. I bought all rubber seals from Dennis Carpenter and they worked just fine, have sealed up tight. I know of no dimensional cab differences in the F series. Tip: Remove, cut or grind the tabs in the windshield area of the cab.
4EyedTurd
05-01-2019 03:04 PM
GreatNorthWoods
04-16-2018 04:59 AM
f100today
12-25-2013 08:35 PM
