96 Ford Ranger XLT Ignition Key stuck in off Position
Old 03-17-2014, 12:45 PM
aveluca's Avatar
aveluca
aveluca is offline
My ignition key is stuck / locked in the off position. The first time this happened I jiggled the key while moving the wheel back and forth and it turned. The next time in the truck nothing worked. I let it roll back a bit then tried, pushed the clutch in and put it in neutral, etc it did not move. (Just had the clutch and clutch hydraulics replaced.) The wheel is locked. The key removes from the cylinder.
I know it is easy to replace the Ignition Lock Cylinder when you can turn the key in the run position.
Anyone know how to remove it when locked in off?
Thanks,
Old 03-17-2014, 12:56 PM
smalltrucker's Avatar
smalltrucker
smalltrucker is offline
That happened when my truck was fairly new and cold out. Called Ford dealer and they sent a guy out who know the problem from others. He said the grease in the cylinder can get stiff from the weather or age. He sprayed some WD-40 in the lock and then gave it a couple of good smacks with the end of a 2x4. Worked but he said spray it a couple more times.
Dave
Old 03-17-2014, 02:33 PM
aveluca's Avatar
aveluca
aveluca is offline
Thanks Dave. I'll give that a try.
Old 03-18-2014, 07:49 AM
aveluca's Avatar
aveluca
aveluca is offline
Thanks for the information. Gave the WD 40 and hammer a try. Unfortunately for me it didn't work.
Old 03-18-2014, 07:55 AM
aveluca's Avatar
aveluca
aveluca is offline
Anyone with a Ranger, Bronco, Explorer or something similar, have you had a problem like this, with the key stuck in the off position?
I've read about drilling something out and using channel locks to force the key in the run position. Does this destroy anything besides the key lock cylinder?
Thanks,
Frdtrkrul
1997 - 2003 F150
01-04-2014 04:50 AM
madpogue
08-07-2008 10:20 AM
fourshizl
Electrical Systems/Wiring
05-04-2007 10:22 PM
1988-Ranger
06-07-2004 08:00 PM
lerry
07-06-2001 11:11 AM
Quick Reply: 96 Ford Ranger XLT Ignition Key stuck in off Position
